Change Solver Interfaces
Load a different solver interface in the application.
From the menu bar, go to File > Solver Interface and select a solver interface.
A different solver interface loads without converting the model to the new solver format.
Tip: Click next to a solver interface to change solver profiles.
The following entities are mapped when switching interfaces:
  • Components
  • Property
  • Material
  • Sets
  • Contact
Default attributes across entities are mapped when switching interfaces.
The default card image can be updated across interfaces from the installation location: <ROOT> \hwdesktop\hm\scripts\SolverConvertInterfaces\UnifiedConversion.
