HM_COMMANDFILE_DIR
Sets the location to read/write the command file.
HM_COMMANDFILE_DIR directory
HyperMesh Environment Variable
directory
The path to the directory where the file should be written to and read from. A value of ./ (dot slash) indicates that the start-in directory should be used, which is the default behavior.
Examples
To set the directory: E:/mydir: HM_COMMANDFILE_DIR E:/mydir.
None.
