Edit a Curve with File as the Data Source
  1. From the Bar Chart Define dialog, select a bar series from the list or pick a bar chart from the window.
  2. Select or enter the new data for the vector.
  3. Click Apply.
    The changes to the curve are reflected in the HyperGraph window.
