Exclude a Curve from the Tip-to-tail Calculation
To remove a curve from the calculation process, select the curve(s) from the
Available curves list and click the forward arrow,
, to move the curve(s) to the Exclude column.
- To select non-contiguous curves in a list, select then first curve, then press the Control button while selecting the next curve.
To add the curve back to the Available curves list, select it from the Exclude
list and click the back arrow,
