Each command set has a list of attachments that connect it to other systems. These are
listed on the Attachments tab. You can modify an attachment by highlighting it in the
Attachments list and using the entity collector to the right of the list. Attachments can be
referenced in the Function Builder.Figure 1. Command Sets Panel – Attachments tab
