Opening Model Files
                From the File menu select .
Or
From the Home tools, Files tool group, click the Open Model tool.Figure 1.
                From the Open Model dialog, locate and select the mdl file
                    to be loaded and click Open.
                The model is loaded into the current MotionView window.
Tip: You can also drag and drop the mdl file directly into MotionView.
