Add Object
Use the Add Object tool to add a graphical representation as an object to a specific component (part) or modify an existing object.
The objects that are added to the current model are listed in the Add Objects list. The component with which the object will move is selected from the input collector or Choose From List dialog and is then added to the Move with column next to the corresponding object.
From the Tools menu, select Add Object.
