Image Plane Entity Editor Attributes
Image planes can be edited by selecting an image plane in the Results Browser then changing the attributes in the Entity Editor. Figure 1.
Standard
- ID
- The ID of the image plane.Restriction: This field is not editable.
- Label
- The label of the image plane.
- Visibility
- Turn the display of the image plane on/off in the modeling window.
- File
- The path of the image plane file.Restriction: This field is not editable.
- Zoom
- Activate to zoom the image plane along with the model.
