Select a Projection Rule
From the Plot tools, click the Iso tool.
Figure 1. -
From the Iso panel, click the Projection Rules
button.
The Projection Rule dialog is displayed.
Select the primary and secondary axes from either the global or user-defined
system (selected for Resolved in).
When the primary axis is perpendicular to the shell plane, the secondary axis is used.See the Projection Rule topic for additional information.
