Scripted Plug-ins
The plug-in library supports two interpreted plug-ins based upon the Tcl and Templex scripting languages.
Optional arguments may be passed from XML and queried from the plug-ins using
        the GetOption command. This command has two forms:
- GetOption() - returns the string passed to the plug-in by specifying the argument “opt_str” in the XML.
- GetOption(key) - accepts a key value will return the value of any argument that is not interpreted as a functional argument, such as src, begin, onrecord, etc.
Option strings may contain context variables such as @current_subcase,
          @current_step, etc. The Expression Builder only supports passing
        optional arguments to a plug-in by passing values in the “opt_str”
        argument (the 1st form).
Important: The interpreters used by Result Math scripted
          plug-ins are separate from those that are included in the application. Variables and
          procedures defined in the application are not available to the plug-in
          interpreters.
