Convert CFAST Elements
Use the cfast converter tool to convert CFAST elements into CBAR/RBE3 (spiders). For thermoelastic analysis, the CFAST has no thermal expansion coefficient. CBAR is thermoelastic compatible.
- From the menu bar, click .
- Select elements or properties.
- Select the materials.
- Select the Orientation.
- Select the Inertia.
- Make the rest of your selections.
Click OK.
