Create Field From Free-Body Sections
Use the FBD Manager to create pairs of entities, <field, table>. Translational degrees of freedom and Rotational degrees of freedom are separate fields. This tool creates a field per loadcase and free-body section.
From the Post ribbon, select the FBD Manager tool from
the Plot group.
The FBD Manager dialog opens. - Select free-body sections.
- Select loadcases to consider.
- From the Options tab, define the Tolerance.
- From the Export tab, select Free body forces/moments, Grid point forces/moments, or Displacement/Rotation.
- If Grid point forces/moments is selected, select relevant contributions to take into account.
Click
The Create Fields from FBD dialog opens. - Select sources to create field based on result type and click Create.
