Rigid Patch
A common realization for Explicit analysis that has a meshed patch defined as the interface.
Feature
Hole
It looks like a Hole to realize to
Projection
It will project to the mesh and select whatever it can find
Connect Outer Layer (Hole Only)
How many layers into the mesh it will select, like washer layers.
None
Just the hole
Every Node
Single washer layer
Every other Node
Single washer layer alternating nodes
Two Layers
Two washer layers deep
Layers for Element Selection (Projection Only)
The size of the element selection.
Duplicate Elements (Projection Only)
Whether the Attachment will generate duplicate elements or move the elements into the Attachment definition.
Solid Hole Nodes
How do you want it to connect to solid holes.
  • Edge Nodes: top and bottom Edges only
  • Interior Nodes: select all of the nodes in the interior hole
  • Face Nodes: select only the nodes on the face of the solid hole
Use Hole or Washer
Fill Hole
Fill the hole with the Patch
Use Washer
Create a patch on the washer layer of the hole
Use Both
Both the Washer and the hole will be used
