Add metadata to all types of entities. The added metadata can be saved to an
*.hm file.
Restriction: Export of metadata to solver decks is
currently not supported.
Open the Add Metadata dialog in the following ways:
Right-click on an entity or entity folder in the Model Browser and select Add
Metadata.
Adding metadata by selecting a folder adds
metadata to all the entities under the selected folder. Selecting a
single entity or multiple entities of the same type adds metadata to the
selected entities.
Right-click on the Metadata category in the
Entity Editor and select
Add.Figure 1.
Define the metadata tag(s) in the dialog.
There are 3 types of metadata supported:
Double
Supports adding metadata with decimals.
Integer
Supports adding metadata with integers.
String
Supports adding metadata with alphanumeric characters.
Note: The same name with different case and names with
just numerical characters are not allowed.
Click Apply to add metadata and keep the dialog open, or
click OK to add metadata and close the dialog.
Once the metadata is added, it is shown in the Entity Editor
under the Metadata category.Figure 3.
By right-clicking on the any metadata, it can be added as a browser column in the
supported entity views for bulk reviewing or editing.
An existing metadata can be applied to other entities of the same type from the
browser column.Figure 4.
An existing metadata can be removed/deleted using the Remove
option in the Entity Editor.Figure 5.
