Jump to main content
HyperWorks
HyperWorks
2024.1
Index
  1. Home
  2. Manage Files and Data
  3. Export Files
    Export various file types from the selected client to another format.
  4. CAD Export
    Learn about the CAD readers supported by the application and the options available for exporting CAD geometry data.
  5. Supported CAD Writers
    Overview of the supported formats, versions, and file extensions.
  • Welcome
  • What's New
    View new features for Altair HyperWorks 2024.1.
  • Get Started
  • Tutorials
  • Tool Finder
  • Manage Files and Data
    • Supported File Types
      The following file types can be read, depending upon the active application.
    • Create New Files
      Create a new file.
    • Open Files
      Open a file.
    • Import Files
      Import various file types into the selected client.
    • Warning Messages When Loading Files
      When loading an .hm file, you may receive a warning message depending on the version and solver interface in which the file was last saved.
    • Change Solver Interfaces
      Load a different solver interface in the application.
    • Conversion Between Solver Formats
    • Load Files
      Load command files, scripts, solver template files, preferences, or the Metadata Table.
    • Save Files
      Save all of the data in your current session.
    • Export Files
      • CAD Export
        • Supported CAD Writers
          • CATIA Composites Link Writer
            Use the CATIA Composites Link option to export composite drape data.
          • FiberSim Writer
            Use the FiberSim option to export composite data.
          • IGES Writer
          • Inspire Writer
          • JT Writer
          • Multiscale Designer Writer
          • Parasolid Writer
          • STEP Writer
        • CAD Export Options
          CAD writers provide options for processing data during export.
        • CAD Export Message Files
          When a CAD file is exported from the application, a .msg file is created, or appended to, in the current working directory.
      • Solver Deck Export
        Export solver input files.
      • 3D Model Export
        Export 3D models.
      • Curve Export
        Export plot data in several different formats so that it can be read by other software applications.
      • Connector Export
        Learn about exporting connector files.
      • HyperMesh Comments
        If you insert special comment cards into your input deck, you can provide HyperMesh with additional information about the colors and names of entities. You can also use comments to preserve information that is not supported by a particular solver, for example, assemblies or system references.
      • Export Settings
        Export settings for AMF, AVI, H3D, JPEG, and GIF files.
    • Include Files
      Most FEA solvers allow you to organize the input deck into separate files and provide a mechanism to include (or refer) these files in the main input deck.
    • Import Templates
      Templates can be imported by means of the File > Import menu.
    • Take a Screen Capture
      Record a video or take a snapshot of the screen.
    • Convert Units
      Use the Units tool to convert a finite element model from its initial unit system to a new unit system.
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Meshing and Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Developer
    The Developer ribbon contains tools for automation and customization.
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
Format Latest Version Supported File Extensions Supported
CATIA Composites Link .h5
FiberSim .h5
IGES
  • v6.0
  • JAMA-IS
  • .iges
  • .igs
Inspire 2024 .stmod
JT 10.7 .jt
Multiscale Designer Writer 2021 .h5
Parasolid v35.0.170
  • .x_t
  • .x_b
  • .xmt_txt
  • .xmt_bin
STEP AP214
  • .step
  • .stp
© 2024 Altair Engineering, Inc. All Rights Reserved.
