Imprint
Use the Imprint tool to imprint geometry or mesh onto target surface/lines or elements creating new edges/fixed points or a mesh patch respectively.
Imprinting points on lines or surfaces creates geometry vertices similar to using the Split: Interactive tool. Imprinting surfaces onto surfaces imprints all of the source surfaces' edges onto the target surfaces.
Imprinting node list obeys post imprint options of FE tab in
Note: Node list/elements imprint to
CAD surface is not possible.
Imprinting elements / FE geometry to elements / FE geometry obeys post
imprint options of FE tab in .
From the 2D ribbon, click the Imprint tool.
Select source to imprint.
- On the guide bar, activate the Source selector and choose whether to imprint lines, nodes, node list, points, surfaces, or elements using the drop-down menu.
- Make your selection in the modeling window.
Select imprint targets.
- Optional:
On the guide bar, click
to define imprint options.
- Click Preferences to define CAD/FE topology revision options.
- Select the FE tab to expose additional options related to FE geometry.
- From the FE tab, select Topology color mode to change the face color mode to topology
- Optional:
Use the microdialog to define the direction on
imprint.
Restriction: This is only available for mesh imprinting to target FE geometry or elements.
On the guide bar, select the Use
anchors check box to select the nodes to be fixed in the
destination mesh during mesh imprint.
- Click Imprint.
Tip:
- Split multiple surfaces with multiple lines at once.
- Use the Split: Interactive tool to untrim previously imprinted surfaces.
- Use the Stitch tool to suppress imprinted edges.
CAD Options
- Maximum imprint distance
- Use maximum imprint distance between source and target geometry.
- Maximum distance
- Enter an imprint distance.
- Line extension method
- Select a line extension option.
- Keep line endpoints
- Keep line endpoints when extending lines.
- Surface imprint method
- Select which lines to imprint.
- Do not imprint internal edges
- Skip internal edges and common edges of selected surfaces.
- Do not imprint near existing edges
- Skip edges too close to pre-existing features.
FE Geometry Options
- Maximum distance
- Post imprint options
- None
- Simple method to imprint source on target surface.
- Create patch between imprinted edges
Figure 3.
- Move target imprint edges to source
Figure 4.
- Move source to target
Figure 5.
- Create elements in
- Select to create imprint or patch elements in the following:
- Source component
- Current component
- Destination component
- Do not remesh/rebuild extension
- Use to avoid remesh or rebuild of the patch elements.
Figure 6.
- Closed loop for node list selection
- Use to close the loop of selected node list.
Figure 7.
- Do not add fixed points/edges on nodes imprint
- Use to imprint nodes on FE geometry without fixed points or edges.
Figure 8.
