Unsplit Surface Edges
Use the Split/Stitch tool to remove split lines so that split surfaces return to their previous unsplit state.
Note: This tool is supported for FE geometry.
From the Topology ribbon, click the Split/Stitch tool.
- From the guide bar, select Unsplit.
Select Points, Surface Edges, or
Surfaces.
- Unsplit will suppress fixed points.
- Free and shared surface edges are handled differently. For free edges,
the below options are available:
- Generate a Straight Line Between Vertices
- Extending the Edges Using Adjacent Edges as a Guide
Figure 3.
- Select surfaces to remove all split lines for one or more surfaces
On the guide bar, complete one of the following:
- Click
to apply and stay in the tool.
- Click
to apply and close the tool.
- Click
to exit the tool without applying.
- Click
