Set Up Design Space Libraries
A Design Space library is an automotive focused library that can be used to rapidly create full vehicle architecture concept models.
The library consists of basic primitives that can be positioned and edited to
generate the appropriate design space.Figure 1.
From the Assembly ribbon, click the satellite icon
that appears when you hover over the Parts tool.
The Part Browser opens. -
In the Part Browser, right-click and select from the context menu.
The Libraries dialog opens.
Register and connect to a new library.
Click
to register a new library.
- In the Library template field, select DesignSpace.
- In the Library path field, enter the desired library path.
- In the Library name field, enter a name for the library.
- Click Add.
- Click Connect.
Click
Open the contents of the library.
Load primitives from the DesignSpace.hm file.
- In the Part Browser, right-click on the part(s) to load and select from the context menu.
- In the Change Representation dialog, select DesignSpace.
- Click OK.
