Absorb Members
Use the Absorb tool to reverse engineer a skeleton model using lines or 1D elements as input.
From the Skeleton ribbon, click the Absorb tool.
- Select lines or elements.
Click
to define options.
- Create joint legs
- Legs are created at each joint. The legs that are generated span 30% of the member size.
- Break angle (degrees)
- Max angular deviation that is considered a straight member.
- Group prefix
- Named prefix to use for each new member.
On the guide bar, click one of the following:
- Apply and stay in the tool
- Apply and close the tool
- Exit the tool without applying
