Change Part of a Curve's Math Expression
- To display the Parameters Browser, click in any client beside HyperMesh.
Right-click within the white space of the browser and
select Expand All.
The browser is expanded to show the entire contents of the session.
Under Y vector for a math curve, activate the check box next to
Expression.
A new row is added to the parameter table in the lower half of the Parameters Browser.
Click the ellipse button,
, next to the default math expression to display the More Options dialog.
- In the Name field in the parameter table, enter a description for the parameter.
- Change Value type to Range.
Set the Default value.
- In the Expression text box, highlight the default value. You can highlight multiple occurrences of the default value.
- Click OK.
Click Save,
, to save the script template.
- Click to display the Flexible Report Templates dialog.
- In the Expression field, change the default value.
Click Apply.
The session is recreated using the new value in the math expression.
