Change Deformation Scaling Value
Change the deformation scaling value in HyperView.
HyperView
From the View Controls toolbar, click .
In the pop-up dialog
, input the scale factor to set for deformation.
Note: This tool provides a quick way to set the Value field in
the Deformation panel without opening the panel. Other deformation settings are
as set in the panel. For more information, see the Deformed topic.
The value specified is applied uniformly to all components. To specify individual scale factors for X,Y,and Z, use the Deformation panel.
