Run Model Check
Find all entities in your model that failed the active checks in the Model Checker.
- Open the Model Checker.
In the Active Status column, select the checkbox of the checks to
perform.
Only active checks will be considered.
Run checks.
- Run all active checks by right-clicking in the white-space of the Model Checker and selecting Run from the context menu.
- Run all active checks in a Check Folder by right-clicking on the folder and selecting Run from the context menu.
- Run a single check by right-clicking on a check and selecting Run from the context menu.
A list of failed checks display, along with the entities in your model that failed the check.Figure 1.
Perform correction.
- Perform automatic correction by right-clicking on the failed check or failed entity and select Apply Auto Correction from the context menu.
- Perform manual correction by right-clicking on the failed check or failed entity and select Apply Manual Correction from the context menu.
- Optional: Export a detailed report of the checks that were run by right-clicking in the white-space of the Model Checker and selecting Export Results from the context menu. You can export all columns by selecting Export detailed CSV report.
Tip:
- You can filter checks by right-clicking in the white-space of the Model
Checker and selecting one of the following options from the context menu: Show only run checks, Show only failed
checks, Show only active checks, or Show all checks.
Figure 3.
You can also combine a search check with an Entity type or card image.
Figure 4.
- Show, hide, and isolate failed entities in the graphics area by right-clicking on the failed entity and selecting Show, Hide, Isolate only from the context menu. In case of element/node checks, this action will be performed on all failed entities associated with the check.
- Cross reference failed entities by right-clicking on the failed entity and selecting XRef Entities from the context menu.
- Review failed entities in the graphics area by right-clicking on the failed entity and selecting Review from the context menu.
- View the failed nodes/elements in a new window, provided the failed count is less than the threshold limit (default 1000), by right-clicking on the failed elements/nodes and selecting View from the context menu.
- Delete selected entities or failed entities by right-clicking on the entity or check and selecting Delete from the context menu.
- For more information on filtering, refer to Use Predefined Filters to Build a Search.
