MV-8002: Multi-Maneuver Events
In this tutorial, you will learn how to define end conditions for a maneuver or a sub-event, write parametric expressions, and to define events as multiple sub-events executed sequentially
- End conditions
- Conditions to end a particular maneuver before given simulation end time.
- Multi-maneuver events
- Events consisting for more than one maneuver – these maneuvers are executed sequentially.
- Parametric Expressions
- In a multi-maneuver event, expressions need to be re-evaluated before
the start of the maneuver in order to maintain the continuity of the signals.
- { Expression in Curly Braces }
- Instruction to driver to evaluate the expression before giving it to MotionSolve
- {SIGNAL}
- Evaluated as VARVAL(signal solver variable id)
- {SIGNAL_0}
- Evaluated as Signal Value at the end of last maneuver
- {%SIGNAL}
- Evaluated as {SIGNAL} – {SIGNAL_0}
Assemble the Vehicle
Follow the instructions in Step #1 of tutorial MV-8000 to create the vehicle
with the topology as provided below.
Page | Label | Selection |
1 | Model type | Full vehicle with advanced driver |
2 | Driveline configuration | Front wheel drive |
3 | Vehicle body | Body |
3 | Front subframe | None |
3 | Front suspension | Frnt macpherson susp (1 pc. LCA) |
3 | Steering linkages | Rackpin steering |
3 | Rear subframe | None |
3 | Rear suspension | Rear quadlink susp |
3 | Powertrain | Linear torque map powertrain |
3 | Tires | AutoTires |
4 | Steering column | Steering column 1 (not for Abaqus) |
4 | Steering boost | None |
5 | Front struts | Frnt strut (with inline jts) |
5 | Front stabilizer bars | Frnt stabar with links |
5 | Rear struts | Rear strut (with inline jts) |
5 | Rear stabilizer bars | Rear stabar with links |
6 | Front jounce bumpers | None |
6 | Front rebound bumpers | None |
6 | Rear jounce bumpers | None |
6 | Rear rebound bumpers | None |
7 | Disk brakes | Disk brakes |
7 | Front driveline | Independent fwd |
8 | Aerodynamic Forces | None |
9 | ABS/ESP System | None |
9 | Traction Control | None |
10 | Drive system | Altair Driver |
11 | Finish |
Adding Driver Analysis
Use the Task Wizard to load the driver analysis.
Figure 2. -
Select the AltairDriverFile as the Event Type and click
OK.
Figure 3.
Write the Altair Driver File (ADF)
We will model a Fish Hook Event using three sequential maneuvers.
Open any text editor, copy and paste the following text, and save the text file
as multievents.adf.
Important: All blank lines must be removed prior to saving the file!
Be sure to read through the comments for a better understanding on what is written in the ADF.
$-----------------------------------------------------------------ALTAIR_HEADER [ALTAIR_HEADER] FILE_TYPE = 'ADF' FILE_VERSION = 2.0 FILE_FORMAT = 'ASCII' $--------------------------------------------------------------------------UNITS [UNITS] (BASE) {length force angle mass time} 'meter' 'newton' 'radians' 'kg' 'sec' $--------------------------------------------------------------VEHICLE_IC [VEHICLE_INITIAL_CONDITIONS] VX0 = 17.5 VY0 = 0.0 VZ0 = 0.0 $--------------------------------------------------------------STEERING_STANDARD [STEER_STANDARD] $Upper and lower bounds are kept to match the event requirement of saturating at $270 deg and -540 deg respectively MAX_VALUE = 4.712 MIN_VALUE = -9.425 SMOOTHING_FREQUENCY = 5 INITIAL_VALUE = 0.0 $--------------------------------------------------------------THROTTLE_STANDARD [THROTTLE_STANDARD] MAX_VALUE = 1 MIN_VALUE = 0 SMOOTHING_FREQUENCY = 5 INITIAL_VALUE = 0.0 $---------------------------------------------------------------BRAKING_STANDARD [BRAKE_STANDARD] MAX_VALUE = 1 MIN_VALUE = 0 SMOOTHING_FREQUENCY = 5 INITIAL_VALUE = 0.0 $-----------------------------------------------------------------MANEUVERS_LIST [MANEUVERS_LIST] {name simulation_time h_max print_interval} 'GO_STRAIGHT' 2.0 0.01 0.1 'LEFT_TURN' 10.0 0.001 0.1 'RIGHT_TURN' 10.0 0.001 0.1 $-----------------------------------------------------------------MANEUVER_1 [GO_STRAIGHT] TASK = 'STANDARD' (CONTROLLERS) {DRIVER_SIGNAL PRIMARY_CONTROLLER ADDITIONAL_CONTROLLER} STEER OL_CONSTANT_STEER NONE THROTTLE FEED_FORWARD_TRACTION NONE BRAKE FEED_FORWARD_TRACTION NONE $---------------------------------------------------------------------MANEUVER_2 [LEFT_TURN] TASK = 'STANDARD' (CONTROLLERS) {DRIVER_SIGNAL PRIMARY_CONTROLLER ADDITIONAL_CONTROLLER} STEER OL_LEFT_STEER NONE THROTTLE FEED_FORWARD_TRACTION NONE BRAKE FEED_FORWARD_TRACTION NONE $The TIME end condition defined below will trigger the Roll Rate end condition after the time value (3s) $We want to end the left turn maneuver if the roll rate reaches steady state in other words, d(Roll rate)/dt = 0 any time after the time value (3s $ Operator definition: SS = Steady State, GT = Greater Than (END_CONDITIONS) {SIGNAL GROUP ABS OPERATOR VALUE TOLERANCE WATCH_TIME} TIME 0 Y GT 3 0 0 ROLL_RATE 1 Y SS 0 0.005 0.5 $---------------------------------------------------------------------MANEUVER_3 [RIGHT_TURN] TASK = 'STANDARD' (CONTROLLERS) {DRIVER_SIGNAL PRIMARY_CONTROLLER ADDITIONAL_CONTROLLER} STEER OL_RIGHT_STEER NONE THROTTLE FEED_FORWARD_TRACTION NONE BRAKE FEED_FORWARD_TRACTION NONE $--------------------------------------STEER for Maneuver 1 [OL_CONSTANT_STEER] TAG = 'OPENLOOP' TYPE = 'CONSTANT' VALUE = 0 $--------------------------------------STEER for Maneuver 2 $Ramp up the steering wheel @ 360 deg per second [OL_LEFT_STEER] TAG = 'OPENLOOP' TYPE = 'EXPRESSION' SIGNAL_CHANNEL = 0 EXPRESSION = '{STEER_0} + {%TIME}*PI*2' $--------------------------------------STEER for Maneuver 3 [OL_RIGHT_STEER] TAG = 'OPENLOOP' TYPE = 'EXPRESSION' SIGNAL_CHANNEL = 0 EXPRESSION = '{STEER_0} - {%TIME}*PI*2' $--------------------------------------THROTTLE and BRAKE controller for entire event [FEED_FORWARD_TRACTION] TAG = 'FEEDFORWARD' TYPE = 'FOLLOW_VELOCITY' LOOK_AHEAD_TIME = 0.5 DEMAND_SIGNAL = 'DEMAND_VEL' $----------------Demand Velocity [DEMAND_VEL] TYPE = 'CONSTANT' VALUE = 17.5
Right-click on AltairDriverFile and select
Edit Event.
Figure 5.
Enter the multievent.adf file and run the simulation.
Figure 6.
Plot in HyperGraph the Steering Angle and Roll Rate.
Figure 7. Steering Angle
Figure 8. Roll Rate
The plots show the Maneuver 2 stopping when the roll rate is consistently 0 (with mentioned tolerance) for 0.5 seconds after the 3s. The simulation then changes to the Maneuver 3 with the vehicle turning to the right as specified in the multievent.adf.Figure 9.
