/ALE/LINK/ON
Engine Keyword An ALE link definition /ALE/LINK/VEL (Starter) which was deactivated during a previous Engine run can be activated again with this keyword.
/ALE/LINK/ON
ID1, ..., IDn
Definition
| IDi | Identifiers of ALE links (Starter) |
- This keyword can only activate ALE links which are defined in Starter /ALE/LINK/VEL.
- This keyword cannot activate ALE links which are defined in Engine /ALE/LINK/VEL. This ALE link (Engine) is active only during the current run.
