/ANIM/SHELL/IDPLY
Engine Keyword Generates animation files containing integer value, defining if a shell belong to a given ply.
/ANIM/SHELL/IDPLY/Keyword4
Definition
Keyword4 Ply output. 2
I
Ply ID number
ALL
All the plies.
  1. The contour animation results can be interpreted as:
    Animation Result Value
    Shell does not belong to ply
    1
    Shell belongs to ply
    -1
    Shell belongs to ply, and has failed
  2. Ply ID number is prop_ID from /PROP/TYPE19 (PLY)/prop_ID or ply_ID from /PLY/ply_ID.
