/IMPL/MUMPS/OUTCORE
Engine Keyword MUMPS solver will use minimum in-core memory.
/IMPL/MUMPS/OUTCORE
  1. Normally, MUMPS automatically manages the use of in-core and out-of-core memory. This keyword allows you to force MUMPS of minimum in-core use, in case of a memory problem or reserving part of the memory for other applications.
