/MAT/LAW66
Block Format Keyword This law models an isotropic tension-compression elasto-plastic material law using user-defined functions for the work-hardening portion of the stress-strain (plastic strain versus stress). This law can be defined for compression and tension.
/MAT/LAW66/mat_ID/unit_ID
mat_title
ρ i
E υ Chard Fcut Fsmooth Iyld_rate
Pc Pt Ec RPCT
Read only if Iyld_rate = 0, 1 or 2
fct_IDc fct_IDt Fscalec Fscalet
ε ˙ 0 c σ y 0 VP
Read only if Iyld_rate = 3
Frate_IDc Frate_IDt Fscale_ratec Fscale_ratet
Read only if Iyld_rate = 4
NFUNCC NFUNCT
For each NFUNCC
fct_IDc ε ˙ i c Fscalec
For each NFUNCT
fct_IDt ε ˙ i t Fscalet
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit identifier.
mat_title Material title.
ρ i Initial density.
(Real)
[ kg m 3 ]
E Young's modulus.
(Real)
[ Pa ]
υ Poisson's ratio.
(Real)
Chard Hardening coefficient.
= 0
Hardening is full isotropic model.
= 1
Hardening uses the kinematic Prager-Ziegler model.
= between 0 and 1
Hardening is interpolated between the two models.
(Real)
Fsmooth Smooth strain rate option flag.
= 0 (Default)
No strain rate smoothing.
= 1
Strain rate smoothing active.
(Integer)
Fcut Cutoff frequency for strain rate filtering, Appendix: Filtering.
Default = 1030 (Real)
[Hz]
Iyld_rate Rate effect on the yield stress flag.
= 1 (Default)
Using Cowper-Symonds:
1 + ( ε ˙ ε ˙ 0 ) 1 c
= 2
By using:
1 + cLn ( ε ˙ ε ˙ 0 )
= 3
By using two load curves to scale the yield stress (fct_IDc) in compression and tension (fct_IDt).
= 4
By using different functions for compression and tension for different strain rate values.
(Integer)
Pc Limit pressure in compression.
Default = 0 (Real)
[ Pa ]
Pt Limit pressure in tensile.
Default = 0 (Real)
[ Pa ]
Ec (Optional) Compression Young’s modulus. 2
(Real)
[ Pa ]
RPCT Scale factor used on Pc and Pt. 2
(Real)
fct_IDc Compression yield stress.
(Integer)
fct_IDt Tension yield stress.
(Integer)
Fscalec Scale factor for ordinate (stress) in fct_IDc.
Default = 1.0 (Real)
[ Pa ]
Fscalet Scale factor for ordinate (stress) in fct_IDt.
[ Pa ]
c Strain rate parameter.
(Real)
ε ˙ 0 Reference strain rate.
[ 1 s ]
σ y 0 Initial yield stress.
Default = 0 (Real)
[ Pa ]
VP Strain rate choice flag.
= 0
Strain rate effect on the yield stress is depending on the total strain rate.
= 1
Strain rate effect on the yield stress is depending on plastic strain rate.
In this case, there is no strain rate filtering, so Fsmooth and Fcut are not used. Only available if Iyld_rate = 1 (Cowper Symonds). 3
(Integer)
Frate_IDc Compression strain rate effect function identifier.
(Integer)
Frate_IDt Tension strain rate effect function identifier.
(Integer)
Fscale_ratec Scale factor for ordinate (stress) in Frate_IDc.
[ Pa ]
Fscale_ratet Scale factor for ordinate (stress) in Frate_IDt.
[ Pa ]
NFUNCC Number of compression function.
(Integer)
NFUNCT Number of tension function.
(Integer)
ε ˙ i c ith compression strain rate i =1,NFUNCC.
(Real)
[ 1 s ]
ε ˙ i t ith tension strain rate i=1,NFUNCT.
(Real)
[ 1 s ]
Example (Aluminum)
#RADIOSS STARTER
/UNIT/1
unit for mat
                   g                  mm                  ms
#-  2. MATERIALS:
/MAT/LAW66/1/1
Aluminum
#              RHO_I
               .0027
#                  E                  Nu              C_hard               F_cut  F_smooth Iyld_rate
               60400                 .33                   0                   0         0         4
#                P_c                 P_t
                 500                 600
#   NFUNCC    NFUNCT
         2         2
#funct_IDc                     Epsilon_c             Fscalec
        38                            10                   1
        40                            40                 1.6
#funct_IDt                     Epsilon_t             Fscalet
        38                            10                   1
        40                            40                 1.6
#-  3. FUNCTIONS:
/FUNCT/38
function_38
#                  X                   Y
                   0                  90
                 .08                 170
/FUNCT/40
function_40
#                  X                   Y
                   0                  90
                 .08                 170
#ENDDATA
/END
Example (Optional Compression Young’s Modulus)
#RADIOSS STARTER
## Material Law
/MAT/LAW66/1
20MAT124_20degree
#              RHO_I
1.25000000000000E-09
            210000.0               0.33                 0.0                 0.0         0         1
#                P_c                 P_t                  EC                RPCT
                 0.0                 0.0              70000.
#funct_IDc funct_IDt             Fscalec             Fscalet
        34        34              100.0              200.0
#          Epsilon_0                   c            Sigma_Y0        VP
                 0.0                 0.0                 0.0         0
##HWCOLOR curves 24 9
/FUNCT/24
20deg_TENSION
#                  X                   Y
                 0.0         0.200535124
1.11148000000000E-04          0.23893938
2.47763000000000E-04         0.274602617
3.84248000000000E-04         0.308164207
5.81974000000000E-04         0.354639794
7.98180000000000E-04         0.395218545
1.03131900000000E-03          0.43242102
         0.001382833         0.473801266
         0.001747862         0.508073173
         0.002139804         0.539268776
         0.002704889         0.577068218
         0.003299031         0.610692299
         0.004078009         0.646563755
         0.005715537         0.702190108
                 1.0                0.75
/FUNCT/34
20deg_COMPRESSION
#                  X                   Y
                 0.0         0.709520996
         0.002556758         0.768542475
         0.005112572         0.814793042
         0.007700089         0.850991269
         0.010231756         0.877769462
         0.012846771         0.896395146
         0.015380438         0.909432849
         0.020500175         0.924867455
         0.030979299         0.948100519
         0.073545677         1.001804424
         0.126630132         1.075808748
         0.245056814          1.17707424
                 1.0                 1.2
#enddata
  1. This is an isotropic elastic-plastic law. The yield stress is defined by using the compression and tension yield stress versus effective plastic strain for the both (compression and tension). When exceeded, the two pressures Pt and Pc, determine if the tension yield stress or compression yield stress is used respectively.
    If the pressure is between these two values, the yield stress is given by:
    If − P t ≤ P ≤ P c
    σ y = α σ y t   ( ε p ) + ( 1 − α )   σ y c   ( ε p ) α = P c − P P e + P t
    If P t = P c = 0 , or the pressure is out of the two values range, the yield stress is given by:
    σ y = σ y t ( ε p ) if P ≤ 0
    σ y = σ y c ( ε p ) if P > 0
  2. If Ec is defined, the Young's modulus is defined as:
    • Young’s modulus is E, if P > -RPCT * Pt
    • Young’s modulus is Ec, if P < RPCT * Pc
    • Linear interpolation is done between E and Ec, if -RPCT * Pt < P < RPCT * Pc
  3. Yield stress is computed as:
    If VP= 1:
    σ y ( ε p , ε ˙ p ) = σ y s ( ε p ) + σ y 0 ( ε ˙ p ε ˙ 0 ) 1 c if σ y 0 > 0
    σ y ( ε p , ε ˙ p ) = σ y s ( ε p ) [ 1 + ( ε ˙ p ε ˙ 0 ) 1 c ] if σ y 0 = 0
    If VP= 0:
    σ y ( ε p , ε ˙ p ) = σ y s ( ε p ) if σ y 0 > 0
    σ y ( ε p , ε ˙ p ) = σ y s ( ε p ) if σ y 0 = 0
    with σ y t ( ε p ) being static yield stress and σ y 0 being initial yield stress.
  4. /VISC/PRONY can be used with this material law to include viscous effects.
