/MAT/LAW84
Block Format Keyword Swift-Voce elastoplastic law with Johnson-Cook strain rate hardening and temperature softening. This law allows modeling a quadratic non-associated flow rule.
/MAT/LAW84/mat_ID/unit_ID
mat_title
ρ i
E ν
P12 P22 P33 Q B
G12 G22 G33 K0 α
A ε 0 n C ε ˙ 0
η Cp Tini Tref Tmelt
m ε ˙ α
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit identifier.
mat_title Material title.
ρ i Initial density.
(Real)
[ kg m 3 ]
E Young's modulus.
(Real)
[ Pa ]
ν Poisson's ratio.
(Real)
P12 Yield parameter.
Default = -0.5 (Real)
P22 Yield parameter.
Default = 1.0 (Real)
P33 Yield parameter.
Default = 3.0 (Real)
G12 Flow rule parameter.
Default = P12 (Real)
G22 Flow rule parameter.
Default = P22 (Real)
G33 Flow rule parameter.
Default = P33 (Real)
Q Voce hardening coefficient.
(Real)
[ Pa ]
B Voce plastic strain coefficient.
Default = 0.0 (Real)
K0 Voce parameter.
(Real)
α Yield weighting coefficient.
=1
Swift hardening law.
=0
Voce hardening law.
A Swift hardening coefficient.
(Real)
[ Pa ]
n Swift hardening exponent.
ε 0 Swift hardening parameter.
Default = 0.00 (Real)
C Strain rate coefficient.
= 0
No strain rate effect.
ε ˙ 0 Reference strain rate.
Default = 1030, no strain rate effect
(Real)
[ 1 s ]
η Taylor-Quinney coefficient quantifies the fraction of plastic work converted to heat.
(Real)
Cp Specific heat.
(Real)
[ J kg⋅K ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeaaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada WcaaqaaiaabQeaaeaacaqGRbGaae4zaiabgwSixlaabUeaaaaacaGL BbGaayzxaaaaaa@3DB3@
Tini Initial temperature used in initialization when time=0.
(Real)
[ K ]
Tref Reference temperature.
(Real)
[ K ]
Tmelt Melting temperature.
(Real)
[ K ]
m Temperature exponent.
(Real)
ε ˙ α Strain rate optimization parameter for temperature dependency.
(Real)
[ 1 s ]
Example (Metal)
#RADIOSS STARTER
/UNIT/1
unit for mat
                  Mg                  mm                   s
#-  2. MATERIALS:
/MAT/LAW84/1/1
Swift-voce (metal)
#              Rho_i
                8E-9
#                  E                  Nu
              206000                  .3
#                P12                 P22                 P33                   Q                   B
                 -.5                   1                   3                 524                  25
#                G12                 G22                 G33                  K0               ALPHA
                 -.5                   1                   3                 100                  .5
#                  A                EPS0                   n                   C              EPSDOT
                1000              .00128                  .2                .014               .0011
#                ETA                  CP                Tini                Tref               Tmelt
                  .9         42000000000                 293                 293                1700
#                  m             EPSDOTA
                .921               1.379
#ENDDATA
/END
  1. Yield stress is computed using an analytic expression with a combination of both Swift and Voce models, the strain rate dependency and temperature dependency following Johnson-Cook law.
    σ y ={ α[ A ( ε ¯ p + ε 0 ) n ]+( 1−α )[ K 0 +Q( 1−exp( −B ε ¯ p ) ) ] }( 1+Cln ε ¯ ˙ p ε ˙ 0 )[ 1− ( T− T ref T melt − T ref ) m ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aaS baaSqaaiaadMhaaeqaaOGaeyypa0ZaaiWaaeaacqaHXoqydaWadaqa aiaadgeadaqadaqaaiqbew7aLzaaraWaaSbaaSqaaiaadchaaeqaaO Gaey4kaSIaeqyTdu2aaSbaaSqaaiaaicdaaeqaaaGccaGLOaGaayzk aaWaaWbaaSqabeaacaWGUbaaaaGccaGLBbGaayzxaaGaey4kaSYaae WaaeaacaaIXaGaeyOeI0IaeqySdegacaGLOaGaayzkaaWaamWaaeaa caWGlbWaaSbaaSqaaiaaicdaaeqaaOGaey4kaSIaamyuamaabmaaba GaaGymaiabgkHiTiGacwgacaGG4bGaaiiCamaabmaabaGaeyOeI0Ia amOqaiqbew7aLzaaraWaaSbaaSqaaiaadchaaeqaaaGccaGLOaGaay zkaaaacaGLOaGaayzkaaaacaGLBbGaayzxaaaacaGL7bGaayzFaaWa aeWaaeaacaaIXaGaey4kaSIaam4qaiGacYgacaGGUbWaaSaaaeaacu aH1oqzgaqegaGaamaaBaaaleaacaWGWbaabeaaaOqaaiqbew7aLzaa caWaaSbaaSqaaiaaicdaaeqaaaaaaOGaayjkaiaawMcaamaadmaaba GaaGymaiabgkHiTmaabmaabaWaaSaaaeaacaWGubGaeyOeI0Iaamiv amaaBaaaleaacaWGYbGaamyzaiaadAgaaeqaaaGcbaGaamivamaaBa aaleaacaWGTbGaamyzaiaadYgacaWG0baabeaakiabgkHiTiaadsfa daWgaaWcbaGaamOCaiaadwgacaWGMbaabeaaaaaakiaawIcacaGLPa aadaahaaWcbeqaaiaad2gaaaaakiaawUfacaGLDbaaaaa@81EE@
  2. The effective stress is computed as:
    σ ¯ =f( σ ) = σ T Pσ = σ 11 2 + P 22 σ 22 2 +( 1+ P 12 + P 22 ) σ 33 2 +2 P 12 σ 11 σ 22 −2( 1+ P 12 ) σ 11 σ 33 −2( P 22 + P 12 ) σ 22 σ 33 +( P 33 +3 ) σ 12 2 +3 σ 23 2 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGceaqabeaacuaHdp WCgaqeaiabg2da9iGacAgadaqadaqaaiabeo8aZbGaayjkaiaawMca aaqaauaabeqabeaaaeaaaaGaeyypa0ZaaOaaaeaacqaHdpWCdaahaa WcbeqaaiaadsfaaaGccaWGqbGaeq4WdmhaleqaaaGcbaqbaeqabeqa aaqaaaaacqGH9aqpcqaHdpWCdaqhaaWcbaGaaGymaiaaigdaaeaaca aIYaaaaOGaey4kaSIaamiuamaaBaaaleaacaaIYaGaaGOmaaqabaGc cqaHdpWCdaqhaaWcbaGaaGOmaiaaikdaaeaacaaIYaaaaOGaey4kaS YaaeWaaeaacaaIXaGaey4kaSIaamiuamaaBaaaleaacaaIXaGaaGOm aaqabaGccqGHRaWkcaWGqbWaaSbaaSqaaiaaikdacaaIYaaabeaaaO GaayjkaiaawMcaaiabeo8aZnaaDaaaleaacaaIZaGaaG4maaqaaiaa ikdaaaaakeaafaqabeqabaaabaaaauaabeqabeaaaeaaaaGaey4kaS IaaGOmaiaadcfadaWgaaWcbaGaaGymaiaaikdaaeqaaOGaeq4Wdm3a aSbaaSqaaiaaigdacaaIXaaabeaakiabeo8aZnaaBaaaleaacaaIYa GaaGOmaaqabaGccqGHsislcaaIYaWaaeWaaeaacaaIXaGaey4kaSIa amiuamaaBaaaleaacaaIXaGaaGOmaaqabaaakiaawIcacaGLPaaacq aHdpWCdaWgaaWcbaGaaGymaiaaigdaaeqaaOGaeq4Wdm3aaSbaaSqa aiaaiodacaaIZaaabeaakiabgkHiTiaaikdadaqadaqaaiaadcfada WgaaWcbaGaaGOmaiaaikdaaeqaaOGaey4kaSIaamiuamaaBaaaleaa caaIXaGaaGOmaaqabaaakiaawIcacaGLPaaacqaHdpWCdaWgaaWcba GaaGOmaiaaikdaaeqaaOGaeq4Wdm3aaSbaaSqaaiaaiodacaaIZaaa beaaaOqaauaabeqabeaaaeaaaaqbaeqabeqaaaqaaaaacqGHRaWkda qadaqaaiaadcfadaWgaaWcbaGaaG4maiaaiodaaeqaaOGaey4kaSIa aG4maaGaayjkaiaawMcaaiabeo8aZnaaDaaaleaacaaIXaGaaGOmaa qaaiaaikdaaaGccqGHRaWkcaaIZaGaeq4Wdm3aa0baaSqaaiaaikda caaIZaaabaGaaGOmaaaaaaaa@9885@
  3. The plastic non-associated flow rule is computed as:
    Δ ε p = Δ ε ¯ p ∂ g ( σ ) ∂ σ MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeuiLdqKaeq yTdu2aaSbaaSqaaiaadchaaeqaaOGaeyypa0JaeuiLdqKafqyTduMb aebadaWgaaWcbaGaamiCaaqabaGcdaWcaaqaaiabgkGi2kGacEgada qadaqaaiabeo8aZbGaayjkaiaawMcaaaqaaiabgkGi2kabeo8aZbaa aaa@485C@
    Where,
    g ( σ ) = σ T G σ = σ 11 2 + G 22 σ 22 2 + ( 1 + G 12 + G 22 ) σ 33 2 + 2 G 12 σ 11 σ 22 − 2 ( 1 + G 12 ) σ 11 σ 33 − 2 ( G 22 + G 12 ) σ 22 σ 33 + ( G 33 + 3 ) σ 12 2 + 3 σ 23 2 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGceaqabeaaciGGNb WaaeWaaeaacqaHdpWCaiaawIcacaGLPaaacqGH9aqpdaGcaaqaaiab eo8aZnaaCaaaleqabaGaamivaaaakiaadEeacqaHdpWCaSqabaaake aafaqabeqabaaabaaaauaabeqabeaaaeaaaaqbaeqabeqaaaqaaaaa faqabeqabaaabaaaaiabg2da9iabeo8aZnaaDaaaleaacaaIXaGaaG ymaaqaaiaaikdaaaGccqGHRaWkcaWGhbWaaSbaaSqaaiaaikdacaaI Yaaabeaakiabeo8aZnaaDaaaleaacaaIYaGaaGOmaaqaaiaaikdaaa GccqGHRaWkdaqadaqaaiaaigdacqGHRaWkcaWGhbWaaSbaaSqaaiaa igdacaaIYaaabeaakiabgUcaRiaadEeadaWgaaWcbaGaaGOmaiaaik daaeqaaaGccaGLOaGaayzkaaGaeq4Wdm3aa0baaSqaaiaaiodacaaI ZaaabaGaaGOmaaaaaOqaauaabeqabeaaaeaaaaqbaeqabeqaaaqaaa aafaqabeqabaaabaaaauaabeqabeaaaeaaaaGaey4kaSIaaGOmaiaa dEeadaWgaaWcbaGaaGymaiaaikdaaeqaaOGaeq4Wdm3aaSbaaSqaai aaigdacaaIXaaabeaakiabeo8aZnaaBaaaleaacaaIYaGaaGOmaaqa baGccqGHsislcaaIYaWaaeWaaeaacaaIXaGaey4kaSIaam4ramaaBa aaleaacaaIXaGaaGOmaaqabaaakiaawIcacaGLPaaacqaHdpWCdaWg aaWcbaGaaGymaiaaigdaaeqaaOGaeq4Wdm3aaSbaaSqaaiaaiodaca aIZaaabeaakiabgkHiTiaaikdadaqadaqaaiaadEeadaWgaaWcbaGa aGOmaiaaikdaaeqaaOGaey4kaSIaam4ramaaBaaaleaacaaIXaGaaG OmaaqabaaakiaawIcacaGLPaaacqaHdpWCdaWgaaWcbaGaaGOmaiaa ikdaaeqaaOGaeq4Wdm3aaSbaaSqaaiaaiodacaaIZaaabeaaaOqaau aabeqabeaaaeaaaaqbaeqabeqaaaqaaaaafaqabeqabaaabaaaauaa beqabeaaaeaaaaGaey4kaSYaaeWaaeaacaWGhbWaaSbaaSqaaiaaio dacaaIZaaabeaakiabgUcaRiaaiodaaiaawIcacaGLPaaacqaHdpWC daqhaaWcbaGaaGymaiaaikdaaeaacaaIYaaaaOGaey4kaSIaaG4mai abeo8aZnaaDaaaleaacaaIYaGaaG4maaqaaiaaikdaaaaaaaa@9595@
  4. Temperature is updated using:
    Δ T = ω ( ε ¯ ˙ p ) η ρ C p σ ¯ d ε ¯ p
    Where, ω ( ε ¯ ˙ p ) = { 0 if ε ¯ ˙ p < ε ˙ 0 1 if ε ¯ ˙ p > ε ˙ α ( ε ¯ ˙ p − ε ˙ 0 ) 2 ( 3 ε ˙ α − 2 ε ¯ ˙ p − ε ˙ 0 ) ( ε ˙ α − ε ˙ 0 ) 3 if ε ˙ 0 ≤ ε ¯ ˙ p ≤ ε ˙ α
