*SET_NODE
LS-DYNA Input Interface KeywordDefines a set of nodes based on a list of nodes in various ways.
(1) (2) (3) (4) (5) (6) (7) (8)
*SET_NODE_{OPTION1}_{OPTION2}
set_ID
If OPTION1 = LIST, repeat the following line, as needed.
N_ID1 N_ID2 N_ID3 N_ID4 N_ID5 N_ID6 N_ID7 N_ID8
If OPTION1 = LIST_GENERATE, repeat the following line, as needed.
N_IDB1 N_IDE1 N_IDB2 N_IDE2 N_IDB3 N_IDE3 N_IDB4 N_IDE4
If OPTION1 = COLUMN, repeat the following line, as needed.
N_ID1
If OPTION1 = GENERAL, repeat the following lines for each TYPE used.
TYPE ID1 ID2 ID3 ID4 ID5 ID6 ID7
ID8 ID9 ID10 ID11 ID12 etc
Definition
OPTION1
LIST (Default)
Nodes in the set are listed 8 per line until the next keyword.
LIST_GENERATE
Nodes in the set include all the parts between N_IDB1 – N_IDE1, N_IDB2 – N_IDE2, N_IDB3 – N_IDE3, and so on.
COLUMN
Enter one node per line in a column.
GENERAL
Nodes in the set are defined using the TYPE options defined.
OPTION2
<BLANK> Default
Each set is treated separately. Sets cannot share the same ID.
COLLECT
All *SET_NODE with this option and the same ID are combined together into a single set.
set_ID Node set identifier.
(Integer)
N_ID1 - N_ID8 Node IDs, 8 per line.
(Integer)
N_IDB1 - N_IDB4 First node ID of the range, 4 ranges per line.
(Integer)
N_IDE1 - N_IDE4 Last node ID of the range, 4 ranges per line.
(Integer)
TYPE
ALL
All nodes in the model are added to the set. No entities are listed for this option.
NODE
The listed nodes are added to the set.
DNODE
The listed nodes are removed from the set.
PART
The nodes from the listed parts are added to the set.
DPART
The nodes from the listed parts are removed from the set.
ID1, ID2, ID3, ... Entity IDs, 7 per line.
(Integer)
  1. This keyword maps to /SET.
  2. The adding and removing of nodes in *SET_NODE_GENERAL depends on the order of the TYPE options used.
  3. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
