*SET_SEGMENT_ADD
LS-DYNA Input Interface KeywordDefines a set of segments based on a list of set of segments.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *SET_SEGMENT_ADD | |||||||
| set_ID | |||||||
Repeat the following line as needed.
| Set_ID1 | Set_ID2 | Set_ID3 | Set_ID4 | Set_ID5 | Set_ID6 | Set_ID7 | Set_ID8 |
Definition
| set_ID | Set identifier. (Integer) |
| Set_IDi | Segment set identifier to add in the
set. (Integer) |
- This keyword maps to /SET/GENERAL.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
