Virtual Power Principle
The basis for the development of a displacement finite element model is the introduction of some locally based spatial approximation to parts of the solution. The first step to develop such an approximation is to replace the equilibrium equations by an equivalent weak form. This is obtained by multiplying the local differential equation by an arbitrary vector valued test function defined with suitable continuity over the entire volume and integrating over the current configuration.
∫ Ω ( δ v i ( ∂ σ j i ∂ x j + ρ b i − ρ v ˙ i ) ) d Ω = 0
The first term in Equation 1 is then expanded.
∫ Ω ( δ v i ∂ σ j i ∂ x j ) d Ω = ∫ Ω [ ∂ ∂ x j ( ( δ v i ) σ j i ) − ∂ ( δ v i ) ∂ x j σ j i ] d Ω
Taking into account that stresses vanish on the complement of the traction boundaries, use the Gauss's theorem.
∫ Ω ( ∂ ∂ x j ( ( δ v i ) σ j i ) ) d Ω = ∫ Γ σ [ ( δ v i ) n j σ j i ] d Γ
Replacing Equation 3 in Equation 2 gives:
∫ Ω ( δ v i ∂ σ j i ∂ x j ) d Ω = ∫ Γ ( δ v i ) τ i d Γ − ∫ Ω ∂ ( δ v i ) ∂ x j σ j i d Ω
If this last equation is then substituted in Equation 1, you obtain:
∫ Ω ( ∂ ( δ v i ) ∂ x j ) σ j i d Ω − ∫ Ω δ v i ρ b i d Ω − ∫ Γ ( δ v i ) τ i d Γ + ∫ Ω δ v i ρ v ˙ i d Ω = 0
The preceding expression is the weak form for the equilibrium equations, traction boundary conditions and interior continuity conditions. It is known as the principle of virtual power.
