Edit Material Failure Criteria
Edit material failure criteria for structural solution results.
- On the Project Tree, open the Analysis Workbench.
On the Analysis Workbench
toolbar, click
➔ Safety
Factor.
The Safety Zones dialog will open and display a list of materials as well as the following information:- Safety factor low
- Safety factor high
- TYS [MPa] (Tensile Yield Stress)
- CYS [MPa] (Compressive Yield Stress)
- Under Failure criterion, click the drop-down arrow in each material's row to change the criterion.
For all other factors, click a number in any column to activate a text box. Then
enter the desired value.
Tip: For Safety factor low and Safety factor high, you can also use the sliders in the dialog to edit the values.
