View Material Failure Criteria
View material failure criteria for structural solution results.
- On the Project Tree, open the Analysis Workbench.
On the Analysis Workbench
toolbar, click
➔ Safety
Factor.
The Safety Zones dialog will open and display a list of materials as well as the following information:- Safety factor low
- Safety factor high
- TYS [MPa] (Tensile Yield Stress)
- CYS [MPa] (Compressive Yield Stress)
- Optional:
View safety zone contour by selecting one or more material rows in the
dialog.
Tip: For complex assemblies, you can use the
(Zoom) button to help locate parts.The safety contours for selected parts will appear in the modeling window.
