Delete an Application Definition
Delete unwanted application definition.
The Applications panel lists all the application definitions that you have created. You can delete the unwanted application definitions.
Click
Select App Composer.
Figure 1. App Composer
Click
next to the application definition that you want to
delete.
Click Delete in the context menu.
Figure 2. Delete Application
The application definition is removed from the list.
