Manage Folders and Files
Organize and manage your job files.
The Files tab provides the following functionalities:
- Use the search box to narrow your search for the required directory or file.
- If you know the job input file folder path, then type the folder path in the
location breadcrumbs available at the top of the file list view.
- Add a favorite for quick access to frequently used files and directories by
clicking
- Quickly navigate to your home folder by clicking
By default, files and folders are displayed in a list. You can toggle the view to
display your files and folders as tiles format by selecting
located in the upper right-hand of the page.
Note: If you are not able to perform
any of the folder or file related operations, then contact your system
administrator as this may due to permission issue.
