Set Notification Preferences
Set notification preferences in Access Web to specify how notifications will behave.
Click
Select Preferences.
Access Web Preferences is displayed.
Click Notifications in the left panel.
The Notifications panel is displayed.Note: By default, the Show Notification popup option is enabled.
Figure 1. Notifications
Uncheck the Show Notification option to disable the notification popup.
Tip: You can view the notifications in the Notification Panel if you disable the notification popup.Note: Click
to go back to the previous page.
