Add or Remove List Attributes
Add or remove list attributes in the file and job listing table.
Click
available in the column header of Files, Jobs, Input, Output,
and Running Folder tabs.
For example, if you have selected
in the Jobs tab, then the Job
Select Columns list is displayed. Figure 1. Job Select Columns
in the Files tab, then the
File Select Columns list is displayed. Figure 2. File Select Columns
Note: The File Select Columns displayed is same for Files, Input, Output, and Running Folder tabs. -
Select the attribute(s) to be added to the display by enabling the check box of the attribute.
For example, if you have added CPU % Used attribute then the job list will be updated.
Figure 3. Job List with New Job Attribute
