EDEM Creator
EDEM Creator is the pre-processor for creating an EDEM simulation model, including setting up equipment and defining the generation of bulk materials.
- Set up simulations quickly and logically using EDEM's intuitive and user-friendly interface
- Import equipment Geometry from various CAD files (IGES, STL, STEP, and more)
- Assign motion to equipment (linear, rotational, sinusoidal, force, and torque driven motions, and more)
- Model particle shapes using Multi-Sphere, Polyhedral, and Sphero-Cylindrical particle shapes.
- Automatically create complex shapes using the Sphere Fitting tool
- Easily create flexible materials and fibers using the Meta-Particle feature
- Select an appropriate, highly validated Physics model from a wider range of options
EDEM Creator allows you to set up and initialize your model. It is where you import particles and Geometries and define the other model parameters.
- The Creator Tree
- The Viewer
- The Toolbar and Menu Bar
- The Data Browser
- The Tree Filter
The Creator Tree
The Creator Tree is displayed on the left side of the EDEM window. It contains information about the Project, Bulk Material, Equipment Material, Geometries, Physics, and Environment.
The Viewer
The Viewer displays 3D representations of your particles, Geometry, and fields (if applicable). You can control the rotation, position, and zoom factor of the Viewer using a mouse. There are a number of animation controls displayed below the Viewer.
| Icon | Name | Description |
| Creator | Opens EDEM Creator | |
| Simulator | Opens EDEM Simulator | |
| Analyst | Opens EDEM Analyst | |
| New | Creates a new model | |
| Open | Opens an existing model | |
| Save | Saves an existing model | |
| Help | Displays the online Help | |
| Change Time Step Back | Moves to the first Time Step in the simulation | |
| Change Time Step Forward | Moves to the last Time Step in the simulation | |
| Start Coupling Server | Starts the Coupling Server | |
| Coupling Server Disabled | Disables the Coupling Server | |
| Server Awaiting Connection | Indicates that the Coupling Server has started but is not connected | |
| Server Connected | Indicates that the Coupling Server is connected | |
| Stop Server | Stops the Coupling Server | |
| Filled Display Mode | Displays Geometry as filled | |
| Mesh Display Mode | Displays Geometry as a mesh | |
| Points Display Mode | Displays Geometry as points | |
| Display Particles | Displays or hides all particles | |
| Display Cylindrical Periodic Boundary Conditions | Displays cylindrical periodic boundary conditions | |
| Add Bulk Material | Adds Bulk Material to the simulation | |
| Add Equipment Material | Adds Equipment material to the simulation | |
| Save Material Block | Saves a block of material for a material bed | |
| Transfer Material from Database Materials | Transfers materials to and from the Material Database | |
| Rename Material | Renames the selected material | |
| Copy Material | Copies the selected material | |
| Delete Material | Deletes the selected material | |
| Open GEMM Wizard | Opens the GEMM Wizard | |
| Add Particle | Adds a particle to the Bulk Material | |
| Import Particle | Imports a particle | |
| Export Particle | Exports a particle | |
| Rename Particle | Renames a particle | |
| Copy Particle | Copies a particle | |
| Delete Particle | Deletes a particle | |
| Add Sphere | Adds a sphere to the particle | |
| Copy Sphere | Copies a particle Sphere | |
| Delete Sphere | Deletes a particle Sphere | |
| Add a Geometry | Adds a Geometry | |
| Add a Box | Adds a box from the Geometry dropdown list | |
| Add a Cylinder | Adds a cylinder from the Geometry dropdown list | |
| Add a Polygon | Adds a polygon from the Geometry dropdown list | |
| Import a Geometry | Imports a Geometry from a 3D CAD file | |
| Rename a Geometry | Renames Geometry sections | |
| Copy a Geometry | Copies Geometry sections | |
| Delete a Geometry | Deletes Geometry sections | |
| Merge a Geometry | Merges Geometry sections | |
| Replace a Geometry | Replaces a Geometry section with an alternative Geometry | |
| Add a Motion | Click to add a motion from the dropdown list | |
| Add Linear Translation | Adds linear translation to a Geometry | |
| Add Linear Rotation | Adds linear rotation to a Geometry | |
| Add Sinusoidal Translation | Adds sinusoidal translation to a Geometry | |
| Add Sinusoidal Rotation | Adds sinusoidal rotation to a Geometry | |
| Add Conveyor Translation | Adds conveyor translation to a Geometry | |
| Add Conveyor Rotation | Adds conveyor rotation to a Geometry | |
| Rename a Motion | Renames a motion | |
| Copy a Motion | Copies a motion and applies to the current Geometry or an alternative Geometry | |
| Delete a Motion | Deletes a motion | |
| Move Motion Up | Reorders the motion | |
| Move Motion Down | Reorders the motion | |
| Add Force | Adds force to the Geometry | |
| Add Torque | Adds torque to the Geometry | |
| Add Factory | Adds a material factory to the simulation | |
| Import Factory | Imports a factory | |
| Rename Factory | Renames a factory | |
| Copy Factory | Copies a factory | |
| Delete Factory | Deletes a defined factory | |
| Change Factory | Changes from static to dynamic factory | |
| Add Material Block | Adds a material block to a Geometry | |
| Delete Material Block | Deletes a defined material block | |
| Show Scale Grid | Shows/hides grid while displaying particle shapes | |
| Show Origin | Shows origin and particles as a mesh when displaying particle shapes | |
| Highlight Surface/Meta-Particle | Highlights the selected surface of particle shape/selected Meta-Particle | |
| Add Meta-Particle | Adds a Meta-Particle | |
| Rename Meta-Particle | Renames a Meta-Particle | |
| Copy Meta-Particle | Copies a Meta-Particle | |
| Delete Meta-Particle | Deletes a Meta-Particle |
| File Menu | |
| Save | Saves the current model |
| Save As | Saves the current model with a specific name, or to a specific location |
| Geometry Transforms | Exports Geometry transforms |
| Import Config | Imports a config (*.dfg) file |
| Export Config | Exports a config (*.dfg) file |
| Creator | Starts EDEM Creator |
| Simulator | Starts EDEM Simulator |
| Analyst | Starts EDEM Analyst |
| Recent Files | Displays a list of recently opened files |
| Quit | Exits EDEM |
| Menu | |
| Additional Components | |
| Coupling Options | RecurDyn Coupling Select the checkbox to
view the Import Geometry from RecurDyn
option after you right-click Geometries
in the Creator Tree. This allows you to read a
Once the Geometry is imported and the coupling interface is enabled, RecurDyn can control the Geometry motion. The forces experienced by these Geometries are passed back to RecurDyn, which then calculates any motions resulting from these forces. |
| Enable FlexTire Select the checkbox to display the FlexTire options in the Geometry section. This functionality requires an additional license as it is a product developed by one of Altair's partners. For more information, contact your Altair Sales representative. |
| Solver Options | Solver Options Select the Experimental Contact Models checkbox to show the experimental models in the Physics section. These models have been built into the software, but are not considered to be widely suitable for industrial applications. It is recommended to exercise caution when using these models. |
| Data Browser | |
| Color Options | Select the Text, Link, and Background colors to configure the color of the data browser text and background. |
| Display Options | |
| Default View Projection options | Perspective
Select this option to change the default 3D view to use the perspective projection automatically. The option to change the view to orthographic is available in the View toolbar. |
| Orthographic Select this option to change the default 3D view to use the perspective projection automatically. The option to change the view to perspective is available in the View toolbar. |
| Background Color | Select the fill color of the Viewer background. The background can be colored with a single color or gradient fill. The color change will affect EDEM Creator, Simulator, and Analyst. |
| User Logo | Select the Enable checkbox to display a custom logo. |
| Logo File Path | Click the … icon to browse to the path of the logo file. |
| Scaling in Width | Use the scaling options to position, scale, and specify the opacity as required. |
| Display | Select the Foreground or Background option to display the imported image in front or behind the 3D view. |
| File Locations | |
| Materials Database | Browse to the location of the Materials database used to store and transfer materials to and from simulations. |
| GEMM Database | Browse to the location of the Generic EDEM Material Model database used to import to EDEM. |
| Contact Models | Browse to the location of the custom (user-defined) contact models. For more information about user-defined models, see the EDEM Programming Guide. |
| Particle Body Force | Browse to the location of custom (user-defined) particle body force models. |
| Particles | Browse to the location of particles saved independently of the model for reuse in other projects. |
| Factories | Browse to the location of any user-defined factories. |
| Geometry Import Temporary File Location Override | Select the checkbox to change the temporary file location used during the Geometry import process. Use this option only if there is an issue with using the default TEMP file location. |
| Alternate Windows import method | Select the checkbox when you import a file using Windows. A
command line window is displayed and the command hmbatch
import is executed, and you can view the output.
However, the import operation is executed as normal. |
| Mouse 3D Configuration | These options allow you to modify the sensitivity of the 3D mouse in EDEM. These options allow you to adjust how much the model will move or rotate per movement of the space mouse. |
| Mouse Configuration | |
| Camera Actions | Change the mouse button and modifier key to pan, track, zoom, and
rotate the camera. Modifier keys assign keys to perform the
specified camera action. Note: Select any
unique combination of three mouse buttons and three keys for
each motion. |
| Rotate on Axis | Change the mouse button and modifier key used to rotate on an axis. You can also set rotation on the model or screen axis for both horizontal and vertical rotations. |
| Bin Control | Select an option from the Bin Control Modifier dropdown list to change the color from blue to green. Select the Pan, Track, Axis Locked Rotation, and Free Rotation options using the Bin Control Modifier (default Ctrl) to move the bin. |
| Mouse Sensitivity | Select the Invert Zoom checkbox to switch the direction in which the scroll wheel zooms in or out. |
| Select the Track and Zoom options to alter the mouse sensitivity independently. You can also specify modifier keys for each sensitivity setting. | |
| Rendering Options | |
| Render all using legacy display | Select the checkbox if EDEM cannot use the Computer Graphics Card. This is applicable when using Remote Desktop or EDEM on computers with out-of-date graphics card drivers. |
| Reduce new template details during camera movement | Select the checkbox to speed up the manipulation of the EDEM Viewer when using particle templates. Particles will be visualized as spheres while the view is being adjusted and then switch to templates when the view is fixed. |
| Display Templates | Select the 3D CAD files to be used as particle templates. You use templates as a guide (outline) to help define the shape of your particle in EDEM Creator as well as providing, if required, the shape for calculation of the Center of Gravity and mass moments of inertia, or as a display option in EDEM Analyst. When a
model containing a particle template is saved, an extra file
| Section Options | |
| Creator | |
| Timestep on Switch | Select the Load Last checkbox to automatically load the last Time Step when you switch to the Creator automatically. |
| Hide Options | Select the Hide Electrostatics checkbox to hide the options specific to the Electrostatics model in EDEM Creator. |
| Simulator | |
| Compress Save Data | Select the checkbox to compress the simulation data as it is saved to minimize file size. Unselecting this option will reduce the time taken to save the simulation data but increase the file size. |
| Show Licensed CPUs | Select the checkbox to show the number of CPUs available on the license. These may be CPU’s that the machine has (indicated by the values colored red) and allows you to set up a simulation to run on a machine with more CPU cores than the machine used to create the simulation. |
| Timestep on Switch | Select the Load Last checkbox to view the last Time Step when switching to the Simulator. By default, the current Time Step is displayed. |
| Particle Size Distribution Solver Graph | Select Enable the Particle Size Distribution Solver Graph in the Solve report. This is updated during the simulation and displays the defined factory particle size distribution versus the actual size distribution in the model. |
| Number of Histogram Bars | Select the number of Histogram bars to be displayed from the dropdown list. |
| Analyst | |
| Timestep on File Load | Select the Load Last option to load models into EDEM Analyst with the last Time Step appearing first. |
| Select the Load First option to load models into EDEM Analyst with the first Time Step appearing first. | |
| Display | Select the Auto Update Display checkbox to automatically toggle between updating the display when changing display properties, or an Apply button that must be first selected. |
| Select the Axis Key checkbox to turn the display of the Axis key in the Viewer on or off. | |
| Select the Domain Box checkbox to turn the display of the boundary box (marking the domain edges) in the Viewer on or off. | |
| Select the Timestamp checkbox to turn the display of the time stamp in the Viewer on or off. | |
| Data Export Defaults | Select the default format from the Notation dropdown list when exporting data using the data export tool. Options are Smart, Fixed-Point, and Scientific. |
| Select the corresponding default precision from the Precision dropdown list when exporting data using the data export tool. | |
| Suppress Warning Messages | Select the Suppress Deprecated Contact Model Warning Messages checkbox to hide warning messages about deprecated contact models. This reduces the number of times you will see a warning message if you are using these deprecated contact models for simulations. However, you will not see any future warnings about them being removed or other models which are marked as deprecated. |
| Simulator Engine | |
| Engine Default Settings | Select an engine from the Default Engine
dropdown list. Options are: CPU Solver and
GPU CUDA Solver. Note: In EDEM
Simulator, you can modify the default engine after which this
information is stored for every simulation in the
simulation_name.dfg file. While opening
existing simulations, the engine that is displayed will have the
last saved setting for the simulation. |
| Default Number Of Cores allows you to
specify the default number of cores. When starting a new simulation, EDEM uses the default number of the Maximum Cores available on the local PC. This can be specified once for every user after which EDEM will use the default setting. |
| Units | Select Set All to SI to use the Système International Units System throughout EDEM. |
| Select Set All to CGS to use the Centimeter–Gram–Second system throughout EDEM. | |
| View Menu | |
| Show Particles | Select to turn the particle display in the Creator on or off. |
| Parent-Child Lines | Select to show how Geometries are connected using the Parent-Child hierarchy. Lines will be drawn between connected Geometries. |
| Geometry Origin Axes | Select to see the axes per Geometry element. |
| Themes | Select Legacy (default) or Dark Theme for the EDEM interface |
| Toggle Display Command Line Output | Can be used for debugging. In certain scenarios, this can be used to display specific error warnings. |
| Displays Menu | |
| Show 1 Display | Shows the EDEM window in a single display. |
| Show 2 Displays | Shows the EDEM window in two viewer displays to review different view-points of the model within each window |
| Show 3 Displays | Shows the EDEM window in three viewer displays to review different view-points of the model within each window |
| Show 4 Displays | Shows the EDEM window in four viewer displays to review different view-points of the model within each window |
| Split Display Horizontally | Splits the displays horizontally so that simulations may be simultaneously reviewed qualitatively and quantitatively on the same display |
| Split Display Vertically | Splits the displays vertically so that simulations may be reviewed both qualitatively and quantitatively on the same display |
| Help Menu | |
| Help | Displays information about the EDEM interface |
| About EDEM | Displays the current version of EDEM. The EDEM Version and Revision number are useful for EDEM Technical Support when discussing support cases. |
| About Altair Simulation Products | Displays the Copyright notices, Altair website, License Agreements, and Customer Support information. |
The Data Browser
The Data Browser is an .html page that displays detailed information
about your model. The information displayed is different in the Creator, Simulator,
and Analyst. Right-click the Data Browser and select Save to
save the information in an .html file.
| Section | Description |
| Description | Available in the Project section of the Creator Tree |
| General | Gravity Displays details of the gravity acting in your model as specified in the Creator Tree |
| Materials Lists all the materials used in the model and their properties, as specified in the Materials Editor |
| Energy Displays the total energy in the model at the current time, which is the sum total of the kinetic energy, potential energy, and the energy in any contacts taking place |
| Geometry | Domain Lists the dimensions of the domain as specified in the Creator Tree |
| Sections Lists each section(model) and its properties |
| Geometry Totals Aggregates the details of the number of elements that make up each section of the Geometry |
| Particles | Particles Lists each particle type used in the model and their properties. This contains either sphere data for Multi-Sphere, and Sphero-Cylinder data or mesh data for polyhedral particles. |
| Factories Lists the details of each factory used in the model and their properties as specified in the Creator Tree. The total number of particles created by each factory is also listed. |
| Particle Totals Lists the total number of particles in the model at the current time and for each particle type |
| Contacts | Interactions Lists the interaction types taking place in the model as specified in the Materials Editor |
| Contact Totals Lists the total number of contacts in progress at the current time. The contacts are broken down into contact types. For example, the number of particle A - particle B contacts or number of particle B - surface A contacts. The total number of collisions that have taken place during the Time Step are also listed. |
| Filter Options | |
| Case Sensitive | Select to make string-based comparisons case-sensitive. By default, this option is unselected. |
| Fixed String | Select to perform string-based matching. |
| Wildcard | Select to perform string-based matching with wildcard characters. '?' matches a single character. '*' matches one or more characters. |
