EDEM Solver Capabilities
EDEM contains four solver engines.
The following table summarizes the features available with each of the solver
engines.
| Features | Multi-Sphere CPU | Multi-Sphere CUDA GPU/Multi-GPU | Sphero-Cylinder CUDA GPU/Multi-GPU | Polyhedral CUDA GPU/Multi-GPU |
| Creator Features | ||||
| Meta Particles | Yes | Yes | Yes | Yes |
| Editable Particle Shapes | Yes | Yes | Yes | Yes |
| Transfer Material | Yes | Yes | Yes | Yes |
| GEMM Database | Yes | Yes | No | No |
| Volume Packing | Yes | Yes | Yes | Yes |
| Factories | Yes | Yes | Yes | Yes |
| Size Distributions | Yes | Yes | Yes | Yes |
| Support Multiple Materials/Particles | Yes | Yes | Yes | Yes |
| Shape Library | Yes | Yes | N/A | Yes |
| Import/Export Particle | Yes | Yes | Yes | Yes |
| Motions | Yes | Yes | Yes | Yes |
| Block Factory Import | Yes | Yes | Yes | Yes |
| Simulator Features | ||||
| MBD Coupling Interface | Yes | Yes | Yes | Yes |
| CFD Coupling Interface | Yes | Yes | Yes | Yes |
| Dynamic Domain | Yes | Yes | Yes | Yes |
| Linear Periodic Boundaries | Yes | Yes | Yes | Yes |
| Cylindrical Periodic Boundaries | Yes | No | No | No |
| Track Collisions | Yes | No | No | No |
| Auto Time Step Setting | Yes | Yes | Yes | Yes |
| Auto-Grid Setting | Yes | N/A | N/A | N/A |
| Contact Detection:Active Cell | Yes | No | No | No |
| Contact Detection: Z-Order | No | No | No | No |
| Contact Detection: BVH | No | Yes | Yes | Yes |
| Euler Time Integration | Yes | Yes | Yes | Yes |
| Verlet Time Integration Methods | Yes | No | No | No |
| Batch Mode | Yes | Yes | Yes | Yes |
| Kinematics | Yes | Yes | Yes | Yes |
| Selective Save/Data Export | Yes | Yes | Yes | Yes |
| Block Import Factory | Yes | Yes | Yes | Yes |
| Analyst Features | ||||
| Clipping Planes | Yes | Yes | Yes | Yes |
| Tools | Yes | Yes | Yes | Yes |
| Manual Selections | Yes | Yes | Yes | Yes |
| Geometry Bins | Yes | Yes | Yes | Yes |
| Grid Bins | Yes | Yes | Yes | Yes |
| Export Data | Yes | Yes | Yes | Yes |
| EDEM API | ||||
| Contact Models | Yes | Yes | Yes | Yes |
| Particle Body Forces | Yes | Yes | Yes | Yes |
| Field Data Import | Yes | Yes | Yes | Yes |
| Particle Replacement | No | Yes | Yes | Yes |
| Deformation (API) | Yes | Yes | Yes | Yes |
| Deformation (Coupling Interface) | Yes | Yes | Yes | Yes |
| Custom Properties | Yes | Yes | Yes | Yes |
| Physics Models | ||||
| Hertz Mindlin | Yes | Yes | Yes | Yes |
| JKR | Yes | Yes | Yes | Yes1 |
| JKR V2 | Yes | Yes | Yes | Yes |
| Edinburgh-Elasto-Plastic-Adhesion Model | Yes | Yes | Yes | Yes |
| Bonded V2 | Yes | Yes | Yes | No |
| Archard Wear | Yes | Yes | Yes | Yes |
| Relative Wear | Yes | Yes | Yes | Yes |
| Oka Wear | Yes | Yes | Yes | Yes |
| Linear Spring | Yes | Yes | Yes | Yes |
| Linear Cohesion V2 | Yes | Yes | Yes | Yes |
| Hysteretic Spring | Yes | Yes | Yes | No |
| Electrostatics | Yes | No | No | No |
| Heat Transfer | Yes | Yes | Yes | Yes |
| Standard Rolling Friction | Yes | Yes | Yes | Yes |
| RVD Rolling Friction (Deprecated) | Yes | Yes | Yes | Yes |
| Tavares UFRJ Breakage Model | Yes | Yes | No | No |
| Type C Rolling Friction | Yes | Yes | Yes | Yes |
| Spray Coating Model | Yes | Yes | Yes | Yes |
| Wet Mixing Model1 | Yes | Yes | No | No |
| Hertz Mindlin Nassauer Kuna | No | Yes | Yes | Yes |
| Volume Spring Model1 | N/A | N/A | N/A | Yes |
| Spinning Friction | N/A | N/A | N/A | Yes |
| Effective Sphere Cohesion1 | No | No | No | Yes |
| Tribocharging | Yes | No | No | No |
| Ganser Drag | Yes | Yes | Yes | Yes |
| Haider and Levenspiel Drag | Yes | Yes | Yes | Yes |
| Morsi and Alexander Drag | Yes | Yes | Yes | Yes |
| Schiller and Naumann Drag | Yes | Yes | Yes | Yes |
| Magnus Lift | Yes | Yes | Yes | Yes |
| Saffman Lift | Yes | Yes | Yes | Yes |
- Experimental model.
Note: The existing EDEM API
models must be converted to work on the GPU solver. This process is not automatic,
but information is provided to help you through the process in the . You must update the model to the latest version of the API before
activation of the GPU solver. EDEM also comprises
additional Helper functions to assist with this process and cover many tools
commonly used in the API.
