Applying a Layered Anisotropic to a Face
Apply a layered anisotropic dielectric to a face bordering a free space or dielectric region.
- Define a layered anisotropic dielectric.
- Select the face where you want to apply a layered anisotropic dielectric.
- From the right-click context menu, select Properties.
On the Modify Face dialog, click the
Properties tab.
Figure 1. The Modify Face dialog (Properties tab).
- In the Medium drop-down list, select the layered anisotropic that you want to apply to the face.
- Under Reference direction, specify the Start point and End point to define the principal direction of the layered anisotropic medium.
- Click the OK to apply the layered anisotropic to the face and to close the dialog.
