Applying a Metal to a Face
Apply a metal to a face bordering a free space or dielectric region.
- Select the face where you want to apply a metal.
- From the right-click context menu, select Properties.
On the Modify Face dialog, click the
Properties tab.
Figure 1. The Modify Face dialog (Properties tab).
- In the Medium drop-down list, select the metal that you want to apply to the face.
- In the Thickness field, enter the metal thickness.
Click OK to apply the metallic medium and to close
the dialog.
Note: Closed regions containing metallic faces cannot be set to (solid) PEC.
