The following equations show the method for computing the bushing output for multiple
preloads.
Let:
- n be the number of preloads in the test data;
be the current load case.
- Sort the preloads
and renumber the preloads such that
be the filter output corresponding to the
load case.
be the static response of the bushing
load case.
be the dynamic response corresponding to the
load case.
Then for each preload,
, defines weights
And the total force is calculated as:
as you see detailed in the following figure:
Figure 3.
