2024
Prepare your model and run the simulation.
Prepare your model for wind tunnel analysis using ultraFluidX.
Manage the parts and assemblies that make up your model.
View new features for HyperMesh CFD 2024.
Discover HyperMesh CFD functionality with interactive tutorials and community resources.
Solution-centric workflows allow you to traverse through modeling environments using a dedicated UI layer.
Use the Convert tool to convert entire models between data types.
Manage CAD, FE, and 2D parametric sketch geometry.
Generate surface/volume mesh by defining mesh controls, or interactively create and edit 2D surface mesh.
Prepare your model for a general AcuSolve simulation.
After preparing your model, use the Data Transfer tool to transfer mesh data to the environment used for aerodynamic and aeroacoustic setup.
An assembly is a list of parts and sub-assemblies that organizes your model hierarchically to reflect the data structure of the modeled product.
A part is a geometric object made up of shell elements. Parts can be grouped together into assemblies and sub-assemblies, so that you can organize your model hierarchically.
Create an assembly and add parts to it in the Model Browser.
Edit the name, color, visibility, and associated properties of parts and assemblies using the Property Editor. Rename and delete parts and assemblies.
Each geometry part has a Faceting property.
Set up the wind tunnel and prepare the aerodynamics and parameters of your model.
Submit jobs and view reports.
Post-process the simulation results by creating visualizations and measurements.
Automate simulation processes with templates and utility scripts.
Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
More resources for AcuSolve and ultraFluidX solvers.
