Transfer Data
After preparing your model, use the Data Transfer tool to transfer mesh data to the environment used for aerodynamic and aeroacoustic setup.
From the Home tools, click the Data Transfer tool.
- Select parts or part groups to transfer.
Select a transfer option from the guide bar.
- Discard
- Discard data in the aerodynamics/aeroacoustic setup environment and then transfer data.
- Append and Replace
- If the selected parts are already available in the aerodynamic/aeroacoustic setup environment, replace the existing parts. If the selected parts do not exist, add them.
- Click Transfer.
