2024
Prepare your model and run the simulation.
Prepare your model for wind tunnel analysis using ultraFluidX.
Submit jobs and view reports.
View new features for HyperMesh CFD 2024.
Discover HyperMesh CFD functionality with interactive tutorials and community resources.
Solution-centric workflows allow you to traverse through modeling environments using a dedicated UI layer.
Use the Convert tool to convert entire models between data types.
Manage CAD, FE, and 2D parametric sketch geometry.
Generate surface/volume mesh by defining mesh controls, or interactively create and edit 2D surface mesh.
Prepare your model for a general AcuSolve simulation.
After preparing your model, use the Data Transfer tool to transfer mesh data to the environment used for aerodynamic and aeroacoustic setup.
Manage the parts and assemblies that make up your model.
Set up the wind tunnel and prepare the aerodynamics and parameters of your model.
Use the Run tool to specify the simulation time for a transient run and other setup parameters, as well as submit the actual analysis.
Use the Show Analysis Results tool to open a results file in HyperMesh CFD Post.
View the runs in your current active session and the runs saved in your output directory.
Post-process the simulation results by creating visualizations and measurements.
Automate simulation processes with templates and utility scripts.
Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
More resources for AcuSolve and ultraFluidX solvers.
