Change the Display Options
Click the Sets tool.
- From the Set panel, select a set/group.
- Activate the Show ID check box to display the IDs of the selected entities in a set.
- Click the Color box to change the color of the feature lines of the selected entities in a set.
Use the Draw style options to select the drawing style
for the active set.
Option Description wire Draws a wireframe on the elements or components in the active set. Notice: Available for Component or Element sets only. - Enter a Draw size value to change the thickness of the wire.
