Change the Tensor Size
From the View Controls toolbar, click
- From the Tensor panel, click the Display tab (located in the middle of the panel).
Select an option from the Size scaling drop-down menu and enter in a
value.
Option Description By Magnitude The tensor size is displayed relative to the value of the tensors. Scale value allows you to increase or decrease the size according to a scaling value.
Normalize The tensor is stretched or reduced according to the element size so that the largest component fits in the element. Note: This is set as the default with a value of 1.By Setting this allows you to increase or decrease the scale factor, which in turn affects the length of the arrows. Restriction: This option is only active when By magnitude is chosen.The options are automatically applied to the model as you enter information.
