2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Use the Task Manager to load an XML file that defines tasks and their attributes.
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Retrieves the activity status of an element.
Retrieves the centroidal result of an element specified by element pointer, layer, and index.
Retrieves the configuration of an element specified by a pointer to that element.
Retrieves the value stored in counter.
Retrieves the ID of an element specified by the pointer to the element.
Retrieves the integration point result of an element specified by element pointer, integration point, layer and index.
Retrieves the node-on-element result of an element specified by element pointer, layer, node index, and index.
Retrieves the number of integration points in an element specified by a pointer to that element.
Retrieves the number of nodes associated with an element specified by a pointer to that element.
Retrieves the type of an element specified by a pointer to that element.
Retrieves the user value of an element.
Retrieves the value of an element specified by element pointer.
Retrieves the activity status of a node.
Retrieves the coordinates of a node.
Retrieves the displacement values of the node specified by the node pointer.
Retrieves a node ID.
Retrieves the nodal result of the node specified by the node pointer, layer, and index.
Retrieves the value associated with a node specified by the pointer to the node.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
