2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Use the Task Manager to load an XML file that defines tasks and their attributes.
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Assigns a centroidal result for an element specified by ID, layer, and index.
Assigns a value to the result at an integration point of an element specified by ID, layer, integration point, and index.
Assigns a value to the result at a node-on-element point of an element specified by ID, layer, node index, and index.
Assigns a value to an element identified by ID.
Assigns a value to the result at the centroid of an element specified by element pointer, layer, and index.
Assigns a value to the integration point result of an element specified by element pointer, integration point, layer and index.
Assigns a value to the result at a node-on-element point of an element specified by element pointer, layer, node index, and index.
Modifies the value of an element.
Assigns a value to an element specified by element pointer.
Assigns displacement values to a node specified by ID.
Assigns a nodal result value to a node specified by ID, layer, and index.
Assigns a value to a node specified by ID.
Assigns displacement values to a node specified by the node pointer.
Assigns a nodal result to a node specified by the node pointer, layer and index.
Modifies the value of a node.
Assigns a value to a node specified by the node pointer.
Stores the user value as a result for the given layer.
Indicates to hmmodlib that all nodes and elements have been added to the database. This function must be called before storing the results data.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
