2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Use the Task Manager to load an XML file that defines tasks and their attributes.
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Transfers the current values associated with the element centroidal results to hmreslib.
Transfers the current values associated with the element maximums to hmreslib.
Transfers the current values associated with the elements to hmreslib.
Transfers the current values associated with the node displacements to hmreslib.
Transfers the current maximums associated with the nodes to hmreslib.
Transfers the current values associated with the node results to hmreslib.
Transfers the current values associated with the nodes to hmreslib.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
